1995 Powerstroke Engine PROBLEMS!!
TurboDiesel101
Columbus Ohio
I have a 1995 powerstroke diesel that runs good but after it's been running for a little bit or after you drive it for a few mins, You turn it off and it wont start back up, I've changed the crank sensor, all the ignition componets, fuel filter, glow plugs, glowplug relay. I'm lost and don't know what to do now. Can anyone help. Thanks Dennis :dunno
NJKen
is a daddy!
Central NJ
Search around this site for IPR o-rings. I has been covered many times and there is a wealth of information on it. That is most likely your problem.
Ken
NJKen
is a daddy!
Central NJ
That sums it up pretty good. IPR stands for Injection Pressure Regulator. When they mess up they pretty much prevent high pressure oil from reaching the injectors. Hot oil is thin oil and that is where you find out you have a problem.
Ken
