1991 7.3 idi injectors where do I get them?
MtnHaul
California
I knew the recommendation was always to replace IP and injectors as a matched set but I thought I might get away with breaking the rule here. I think I'll just run extra additive for a while and see if things clear up anymore. Cash is a little tight to be buying a new IP and sticks since the ones I have are working other than a slight knock at cold start. Redline 85+ and Optilube XPD did make a huge difference in just one application.
That would be $623.60 for the 8 injectors.
Would be a good idea to pop test them to see where they
are at, even if new.
I know Justin at R&D sells new Injectors, but takes them
apart to make sure they are balanced.
Justin has his listed for $415 - $545.00
tke395
