1990 F350 7.3idi
duaneboggs
Burns Flat, OK
I guess I'll throw my truck into the arena. It is a 90 that started life as an F250. I converted it to a 1 ton. Changed the rear axle and front hubs so it is a true dually now. Extended cab. Auto trans, 2wd. Approx 104500 original miles. Everthing is in good shape. Radiator, hoses, water pump are less than a year old. SCA's are monitored and in good shape. No leaks, front brakes were repalced when I replaced the hubs. Front tires are 75% rears are 40%. Gooseneck hitch in bed. Dual 5 inch stacks. Body is straight with the exception of the rear dual fender on the drivers side. I lost a tire and tore it off, put a spare fender on but has bad cracks. Paint on truck is no good and bed is different color than cab. No rust on the body. Interior is in good shape and ac works.
On edit: I'm in a spot needing money for a transmission for another truck I've got. I will entertain reasonable offers for this truck.
I also have the original non dually bed and 3/4 ton rearend that will go with it.
Located in western Oklahoma.
email or pm or call me at 580-275-9160.
Thanks,
Duane
