When I put my last engine in ,I wanted a warning buzzer as well as an oil pressure gauge. Too often we get locked into drivingand forget to check gauges often enough-I lost this engine that way.An ounce of prevention is betteren a pound of cure.I wanted a buzzer like I had in the semis I drove,obnoxious in the morning but so helpful when things go bad,like low air pressure-low oil pressure-low vacume & over heating. Buzzes and tells me to pay attention when a problem arises.I needed 1 pressure line for my manual gauge,1 for my stock gauge & one for my low oil pressure sending unit. Looks like I need an "oil pressure manifold" Using what I had laying around I soldered a t fitting to a short peice of sheet metal a little heaver then body metal-I found it in my scrap pile about 16 gauge drilled a hole in it and bolted it to the center bolt on the drivers side.I bent it so it had a lot of pressure against the manifold under the fitting to prevent vibration & stress fracture-put a piece of rubber between the manifold & the t so it wouldn't wear a hole in the manifold. made a new tube for the stock senedr to screw into with a 1/8 fitting on the side,slid the tubing thru a peice of clear vinal tub to prevent chafing. You can see in the pics the stock sender in its origional place and beside the air intake is my manifold.It is easy to get at when working on the engine & not in the way. I used a el-cheapo backup alarm from Autozone,wired the Oil pressure sensor 7 PSI-the over heat lamp sensor added another over heat sensor to the rear of the passenger head -wired those to gether and my vacume switch wired together with the rest.They all go to ground when a problem occures.I had measured the draw on the back up alarm I forget what it was but was low enough that the sensors would handle it nicely.Then I ran 1 wire from the oil pressure sensor (blue wires in the pic)to the alarm hidden way up under the dash.The other side of the alarm is wired to hot when running on the IGN switch.The sensors complete the circuit to ground.Works great-the alarm will shurley wake you up when a problem occures.It however buzzes while starting till the oil pressure is up.Makes a good way to know the system is in working order.
Mr Bill
