stangclassic66
1986 Ford F-250 6.9
Hey Fellas, this is my first post. I have a 1986 F250 with a 6.9L w/ATS turbo and Gear Vendors Under/Overdrive unit. I've owned it for a few months and i'm still learning a ton about it. This site rocks and has a ton of info, thanks!!
One question I have is, what are the fuel tank capacities?
My fuel gauge is acting funny and reads half tank when i've burned about 10-11 gallons and after about 10 more miles it drops all the way to EMPTY. So I took the mileage down and increased the distance I drove after every fillup. I pushed the limit a few weeks ago and the truck died after I started it up one evening. (I switched to the rear tank and it took 3 cranks of about 20 seconds each crank to fire up). I drove it to the gas station and filled the tank up about 19 gallons topped off. I recorded 327 miles on that 19 gallons which turns out to be 17.2 miles per gallon.
In any case, I just wanted to know if the tank is 19-20 gallons or if it's bigger and my pickup tube is broken.
How about the rear tank? I've never pushed that to the limit but it always shows half tank for a few miles then drops to EMPTY just like the front tank. I fill that tank to about 11.4 gallons on average.
Thanks in advance.
Thanks in advance.
