Does anyone have an idea what a 1984 6.9L engine with almost 80K miles on it is worth. It has a turbo of of a 1996 6.5L GM engine on it also (10-12 lbs boost). I know the miles are right because I know all the previous owners. I am located in NE AL.
Thanks, Larry
larry-
here's my rule of thumb. adjust to your taste.
If the motor is still in the truck and you can hear it fire up and run and be able to check for blowby, it's worth 1k tops. Also, look for leaks on the backside of the block/head area. I can buy a wrecking yard motor with a 90 day warranty for 1500 max.
If the motor is removed from the truck and is now sitting on the ground, it's worth 300-500 depending on how much stuff is still remaining on it. big deductions for missing IP and injectors. If you can't hear it run, it's a core motor(paperweight) in my book. Unless the seller has another replacement motor to trade out for the first one, the motor is a core. nobody is their right mind rips out one of these motors for ***** and giggles. There has to be a reason why they busted their knuckles.
As far as the turbo kit is concerned, it's a morphidite. the 1996 GM turbo is not a really good one, so post some pics of the setup and opinion can be rendered.
good luck!
