02' International DT466 needs to start or no work !
monsterB
Truck has been actin' up prior to total let down, if truck hit a long dip or uneven up-and-down roads it would die then start up after.
Every now and thn it would just cut out then start-up again but this was only a few times.
Now truck does not turn over, it will if I jumper wire the starter but will not fire even with the key on and jumping with the wire.
ANYBODY !
THANX !
NJKen
is a daddy!
Central NJ
Start checking all electrical connections. Look at the starter and make sure everything is clean and tite. Look at the batteries and make sure everything is clean and tite. Check the plugs on the ECM, the plugs on the firewall, any plug you can really. It sounds as if something is loose somewhere.
GoodLuck
Ken
Goofyexponent
Mentally Unstable..
Halifax / Nova Scotia
I agree....the new internationals are a wiring nightmare! a little WD 40 on connectors will dry them out if they are wet...good luck!
monsterB
Problem was crank sensor.
THANX FOR THE REPLIES ANYHOW, ONE IS BETTER THAN NONE !!!
NJKen
is a daddy!
Central NJ
Some of the symptoms for a crank sensor where there. The dip in the road part is what threw me. Im glad you got er fixed though. Nothing is worse than an unreliable truck.
Ken
