01 F250 4WD ball joint help
ok, ive got it all striped down.
about to replace leaf springs, and noticed that my ball joints were beyond wasted.
i have a ball joint press, and ball joints.
but...
how do i go about getting the knuckle off?
looks like with a few blows of the baby beater the top one is loose.
ive tried slapping the lowers, but they will not budge.
is there something im missing?
trackspeeder
Stone crusher.
North Branford. CT
Some panther ****, maybe some heat or a fork. Give the knuckle a few hits around the ball joint area. This usually pops the loose. If not break out the heat. If it gets real ugly, break out a pickle fork.
Don't forget to cuss at it. A little sweet talk can scare them off.
there what appears to be a slot in the top, just making sure that these dont spin out or something stupid.
i need a new hammer, my baby beater has a broken handle.
gotta go put a timing light on a 55 buick, i ****** em with PB and buy a hammer while im out.
Clb
Another old truck
nannyfornia
Hit it with the roadmaster! That should fix the ford!
Use the broken handle hammer as a backup on the other side when you hit it with the BFH ya just bought.
Takes alot outa a guy producing twins. :rotflmao
new horrible freight 4 pound sledge did the trick just fine.
ill load the ball joints tomorrow.
are these front ends non align-able? besides toe?
does not appear to be anything to adjust it. like any camber shims.
gotta get new hub seals and tierod seals, kinda chewed em up.
They are.
It's done with that sleeve for the top balljoint. Can get different degrees.
the ******* sleeve on the ball joint press is too short.
the lower ball joint bottoms out on the collar of the press before it comes out :(
well that was a damn chore.
when the leaf springs came out, the driverside had a broken bolt.
all 4 bushings were toast.
all 4 ball joints were wrecked.
shes back to 100% again.
instead of trying to do the ball joints myself, with the press thats very time consuming,
i took them down to the machine shop and used their press.
20 minutes to pull and press..
will never do it any other way...
i spent 20 minutes just looking for a sleeve to use!
then....
after i get her all back together, took her down the freeway, the damn battery light came on!
a new alternator fixed that quick!
