Should have my clutch to begin my ZF conversion in the next week or so. Was under the truck mapping out the process and work ahead of me, realized my 87' has the transfer case shifter coming into the cab at the rear of the trans cover pan on the tunnel. However, My 88' donor truck had the transfer case shifter coming through the floor of the cab to the left side of the cover.
I'd prefer to not cut my floor up and modify the ZF cover plate I have instead. Will the brackets and linkage from my C6/BW1356 swap over to the ZF? Also will the two sticks clear each other?
Haven't seen any setup this way, everyone seems to have the side mount shifter.
