I took the beast for a spin tonight after working on it for 3+ weeks, it's not completely done but it rolls in 2wd anyways. Didn't drive too bad, the brakes felt funny like there was no vacuum - there must be some as my heater doors are moving....I'll have to check that out. The used LUK clutch adjustment needs work, too much freeplay and it takes right off the floor. I have to fabricate the 4wd shifter lever and linkage along with some painting and trimming of the trans tunnel plate around the shifter (rubbing)
Definitely pulls harder, the used 2wd trans seems to work good, probably feel even better with less freeplay and more release bearing pressure. I only took it up to 80km/hr but there was no driveline vibrations....There are some other odds and ends to do but I should have it ready to go to work on Monday with any luck.
