Wide-range ZF-5 poll
How much better is the wide-range ZF-5 vs the diesel gearing? Pick up to 2 answers.
  • I own/have driven the wide-range and I love it!
    Votes: 3 16.7%
  • I own/have driven the wide-range and it's a toss-up for me.
    Votes: 3 16.7%
  • I own/have driven the wide-range and I don't like it.
    Votes: 2 11.1%
  • I just want to vote in a poll!
    Votes: 6 33.3%
  • 'Merica!
    Votes: 8 44.4%
  • I love slushboxes!
    Votes: 1 5.6%
  • Total voters
    18
u2slow
bilge rat
PNW
Yeah you have to build an adaptor.
IIRC it's more than that. Possibly a spacer on the crank, and some way to make the starter reach.
The jist of it is the ZF 6 bell is deeper than a ZF5 because they stopped using a thick factory spacer.
chillman88
Central NY
Just FYI because I was looking.
Watch out.....rrrrrreeeeeerrrrrreeeeeerrrrrrr ........claka claka...... Reeeeeeerrrrrrrreeeeeeerrrrrr......claka push the clutch in before I go crazy! Reeeeeeerrrrrrrreeeeeeerrrrrr!!!!!
The_Josh_Bear
Western WA
Another thing to remember is that they changed the gear ratios for the later diesel ZF5s (the zf5-S47), and sort of split the difference between the earlier close ratio and the wide ratio. Depending on your preferences it might be better to get an S47 transmission.
Looks like the easiest way to the promised land is the S5-47 close ratio. Significantly lower 1st and reverse and 2nd is a little lower to boot. With my 3.55 gearset and 33" tires that would be a great combo for what I use it for. I'll probably end up just rebuilding what I have since I already have the kit...but until then I can dream and do a little research. :Thumbs Up
Laine D
Northern California
To me it depends on power level, gearing, tires and what you use your truck for. I hated mine with 3.55’s and anything hooked to the back. Mainly because I’d drop so far out of the power band my egts would crank up even with the turbo spooling fast. If I shift around 3k it’s not bad but I don’t feel like blowing everbody’s eardrums out when I pop the clutch LOL
First is very nice though
The_Josh_Bear
Western WA
To be honest if I knew I was gonna go with 33" tires I would never have done the 3.55's. Overall I liked 4.10's more. But I'm here now and like it enough to keep it. It was a lot of work!
But it's great on I-90 by my house. I have to take it to get anywhere, speed limit 70 for at least 14 miles to work or Costco or Home Depot, etc. It's fun to be able to get up to speed easily and cruise 75 no problem.
3k is nothing...these babies live in the upper rpm's just fine. :Thumbs Up They love RPM's! Wish mine cooled better. Stupid 7.3 non-cooling mod.
I'm not sure that actually affects the overall engine temperature when looking at a gauge. What it does is to help cool the heads down better so there's less chance of them cracking or even lifting.
The_Josh_Bear
Western WA
Well the temp gauge is in the heads, so that's definitely something. But you rarely hear of a 6.9 cooling issue, and so far in my reading it's all fixable stuff, broken this or that and then they go back to perfect cooling. 7.3's have cooling issues stock, modified, hot ambient, cold ambient, old rad, new rad, etc. They just don't cool as well. The only difference I can see is those ports closed in the head gasket.
ISPKI
Granby CT
7.3s have cooling issues? Only time I ever had a cooling issue was when a piece of debris smashed my AC rad AND my thermostat jammed at the same time. Finally overheated sitting in 100 degree, direct sunlight idling in a parking lot for half an hour while loading up ~400 2x4s on it... Wrecker operator did not like loading that up.
mexicanjoe
texas
Ive got a close ratio ZF5 in my '89 supercab with a 4.10 limited slip axle. I hauled a 4000 pound livestock trailer loaded with about 1,500 load on a warm day...... 70 mph all the way - the tach dancing around 2350 rpm..... because the fan clutch is defective the engine never gets above 160 degrees- but what a roar!!!! Love my old LuLUBell!!
The_Josh_Bear
Western WA
The stock location for the temp gauge sender is in the block.
Well there is that lil fact, lol. So it's the idiot light that's in the head. I replaced that with my real gauge, and had another sitting around so I put that into the passenger head. Sounds like I should put one into the block and see if they read differently in some way.
Yes. I had the aftermarket temp sender in the same location in my Bronco and the temps read higher in warmer weather and while towing. Maybe it means something, maybe it was just another engine in a different vehicle. Some people like to put their senders in the head to monitor the hottest part of their cooling system. I feel like if the block was good enough for the factory, then it's good enough for me. Of course, knowing the (lack of) accuracy in the stock gauge, my theory may be full of holes too.
I also want to add that I put the stock temp sender in the extra hole in the water pump and extended the wire to reach the new location. Again, due to the lack of accuracy in the factory gauge, I wasn't too worried about adding more resistance to the wire. I just hate to see dead factory gauges. They don't have to be accurate, just pretend to be showing something.
dieselmainiac
