zrexryder
I'am going to electric, which pump do you guys recommend?
can you explain the pros an cons on each?
Why is the Carrier pump not good for WMO? Just curious...If I had a fleet of IDI trucks I'd do it to every one of them unless I was running WMO, but for diesel or bio it can't be beat.
in the year i been running electric, i have replaced my holley twice. and the latest one is now starting to act up. i will be swtiching over to a carrier when the funds are there.
holleys have gone down hill in my opinion.
The carrier isn't suitable for frame rail under truck mounting unless you can do something to protect the glass filter bowl. They are not immune to failure either. I've run the Holley and the Carter and will try a Carrier when I have the right application. I haven't had problems with any of them really.
In all fairness, are you using the thing for what it was built for? No . the Holley is a racing pump. It was designed to pour gas into a carb with no resistance at breakneck speeds for short periods of time, it was never intended to force feed diesel under pressure over a long period of time. I was ticked off at my holley when it folded, but knew it was because the thing wasn't designed for teh application and went looking for something that was and that's when I found the Facet Dura Lift ( Carrier ) pump. Each piece of equipment has what it was designed for that it excels at The carrier was designed to pump diesel under pressure over large distances and heights 24 hour a day for extended periods of time. It is purpose built for the kind of thing we do with it
