Not patronizing whatsoever, complete newb to this so any info is appreciated.
Not sure why it would appear to be slower after cleaning. I did not over pressure it at all, seems to spin freely on the shaft, even took it up to 40psi or so with the top off so I could make sure the two pin holes were flowing oil. Would it not spin freely if I overpressured and expanded the bowl? Is it visibly noticeable or a small change in size/shape?
Is it possible it's too thick? I had dialed back on the gas in the warmer weather, it's probably a hair thicker than usual. I do not heat my mixture. As I said before, I think its spinning, but I'm not getting any of the slight "harmonics" like I was on the first pass which makes me think its running slow. Setting pressure at 85-90lbs, it does seem to jump around though while running.
