Acidburn is running a fuge setup that I more or less suggested, (I think) if you are frugal it can be done for 5 bucks over the fuge cost. That will require scavenging and CL finds etc.
In the beginning I ran a power steering pump from the bottom of a 5 gal bucket with a 1200 watt water heater element suspended in the bucket. The pump was driven from a washing machine motor I scavenged.
That steering pump powered one 55GPH fuge that was draped over the side of the bucket. I very quickly upgraded that to a steel 55gal drum. Recently it has been adapted to a two drum fuge system. In the beginning my cost were.
Fuge 135 plus shipping
ball valve and fittings 20.00
Hose free
Motor and pump free
Bucket free
55gal drum free.
Counting valves various pipe and fittings, hydraulic hoses, suction hoses, tires, trailer, banjo couplers, tanks, various hardware and parts, I have less than 1100.00 in TOTAL for everything I use to collect, transport, and process used oil.
My WMO processing inventory Includes
8ft trailer with 6000lb axle $100.00
2 100gal pressure tanks $Free
1 500gal pressure tank, $100.00
2 55GPH fuges $270.00
1 1/2HP washing machine drive motor $Free
Power steering pump and corresponding drive pulley from alternator of same vehicle $Free
3/8 Hydraulic hose $30.00
Various fittings and valves for EVERYTHING $150-200
5 275Gal IBC "totes" $50.00
40' of 1.5" suction line $65.00
Various pipe $50.00
10 55gal drums $Free
4 30gal drums $Free
3 bulk fuel filter housings and filters $165.00
Those figures are totally from memory, I have kept no records, but I know I have saved 3 to 4 times that in fuel cost just by doing rough estimates.
