Kalashnikov
So in the past 6 months my oil problem has gone from adding a couple quarts or so every month or a few weeks to adding a gallon or two every 60 miles or so depending on how fast I drive on the highway. The truck also starts like **** after ruling out everything else. New GPs, good relay, new injectors, rebuilt pump, good timing etc. I recall last year it was a bit rough to start but I also hadn't adjusted timing and I'm not sure what else but it would start on it's own.
I finally pressure washed it last weekend as it was CAKED in oil and grime and while I do have some seepage and leaks, it is not a gallons worth. It actually doesn't even leak on the ground. I had filled up on oil and after driving a couple days, Its barely on the dipstick. I get a constant blue haze when I am just slightly off the pedal driving around and idling so I was kinda suspecting it was burning quite a bit. My oil cooler also start leaking so that doesn't help it. Now I see my oil pan is leaking at the gasket too. I'll pull the valve covers when I get a chance and make sure the guides aren't worn out. I also need to get a compression tester as mine only goes to 300PSI.
Looks like I have another winter project...
