On most Fords I ever messed with, the SRW frame is something like 42" outside measure.
A "dualie" frame is also 42" wide and the axle is quite a bit wider than a SRW.
A genuine DRW chassis-cab truck is industry standard 34-1/2" frame width, with the axle being some 16" or so narrower than a "dualie".
On most SRW trucks I have tried, a DRW wheel will come against the leaf-springs long before it bottoms on the mounting surface.
Also, the rear spring hangers of an SRW are often farther from the rails than those of a "dualie", compounding problems when trying to swap things around.
Of course, there are always exceptions to all of this.
I see many many 3/4-ton SRW trucks of all brands running around my area that have the SRW wheels on the front and DRWs mounted to the rear via thick spacers behind the inside wheels to push them out away from spring interference.
Many of these have the rear wheels just bolted on in no well thought fashion, using flat-faced hub-centric wheels on spacers that have no means of centering the wheels; or, they have lug-centric "coined" wheels mounted on spacers that lack the proper sockets for the "coins" to rest in.
Or worse yet, they have a mixture of junk-yard wheels, some being "coined" lug-centric, some being flat-faced hub-centric, with the odd Chevy wheel thrown in the mix.
All of these scenarios are a recipe for wheel slippage and the resultant wallowing out of the stud-holes and chewing big grooves in the studs.
Best is to MEASURE carefully and swap on a genuine DRW rear with the wheels that are MEANT to be on it.
