argve
Resident Fruitcake
I noticed on a buddies 3/4 ton 85 SRW vs the Enterprise (1 ton dually) - both 2wd - that the front end was much beefier on the E than his. I don't know if it was because of the years difference or that it was F350 vs F250.
On most Fords I ever messed with, the SRW frame is something like 42" outside measure.
A "dualie" frame is also 42" wide and the axle is quite a bit wider than a SRW.
A genuine DRW chassis-cab truck is industry standard 34-1/2" frame width, with the axle being some 16" or so narrower than a "dualie".
On most SRW trucks I have tried, a DRW wheel will come against the leaf-springs long before it bottoms on the mounting surface.
Also, the rear spring hangers of an SRW are often farther from the rails than those of a "dualie", compounding problems when trying to swap things around.
Of course, there are always exceptions to all of this.
I see many many 3/4-ton SRW trucks of all brands running around my area that have the SRW wheels on the front and DRWs mounted to the rear via thick spacers behind the inside wheels to push them out away from spring interference.
Many of these have the rear wheels just bolted on in no well thought out fashion, using flat-faced hub-centric wheels on spacers that have no means of centering the wheels; or, they have lug-centric "coined" wheels mounted on spacers that lack the proper sockets for the "coins" to rest in.
Or worse yet, they have a mixture of junk-yard wheels, some being "coined" lug-centric, some being flat-faced hub-centric, with the odd Chevy wheel thrown in the mix.
All of these scenarios are a recipe for wheel slippage and the resultant wallowing out of the stud-holes and chewing big grooves in the studs.
Best is to MEASURE carefully and swap on a genuine DRW rear with the wheels that are MEANT to be on it.
It actually isn't complicated at all:Wow I didnt know it was that freakin complicated
That's cause they don't pay enough attention to their dimensions - I never even step on the yellow line, let alone cross it - it's all about observing your surroundings and being courteous to others, which I guess many people don't care for no more these days.[/QUOTE]That is probably true, but not a day passes that I don't get crowded over by some "recreational" driver in a hip-fendered dualie who is running with the entire fender and outer wheel ON MY SIDE OF THE YELLOW LINE.
Duane, you're right, even with the factory tow-package my dually's rear packs were much similar to my friend's F250HD's packs. I did of course change that so the leaf packs match the side of trailer I pulled at the time, that's why now my ass end sits as high as it does on a 4x4 truck, but without having them silly 4" blocksPay close attention to the number of leafs in the spring pack if you pull a dually axle from a junk yard. The main sping pack on my F250 and the F350 I pulled my axle from were the same. The F350 had a factory overload spring added. Other than that there was no difference.
Aren't the cab-chassis D80s still only 7ft wide tho? Certainly seems so with the 10-lug F-Superduty trucks, and those are the only pre-metric-lug-pattern trucks that I know have D80s. Some newer F350 pickups (such as the 2000 crew dually that I serviced last weekend) also have the D80, and it's 8ft wide, but it's the wrong lug pattern for you, and spring perches are likely too far apart anyways.Although my truck is a DRW chassis-cab ton, were I to find a Dana-80 one, I would swap in the wider "dualie" rear on account of my steel flat is a full 8-foot wide and the narrower chassis-cab axle is lost under there; a "dualie" axle would put the outer tires closer to the perimeters of the bed and most likely be even more stable.
That's good info Damon. As I have been contemplating getting new tires for the Moose truck, I have been wondering if there was a way to pull off dually tires with a SRW axle. Sounds like you've tried it and confirmed they hit. That saves me some time fooling around with it.
Buy a pair of 19.5" SRW wheels and rubber for the back. With 4500-5000# rating on each tire, you can easily match a dually's axle capacity.
You'll need a pair for the front too tho, and while it would be an awesome setup how expensive would that get, compared to just getting a pair of new 235/85-16s for the front of the truck and then moving all current tires back to the dually axle? If buying all new dually wheels and rubber for them I could see it being about the same overall cost, but with factory dually axles and wheels being fairly reasonably available in junkyards the 19.5s would be the more costly option, methinks.
You'd need 2" or 3" spacers between the hub flange and the wheels. However there is the issue with centering the wheels, as hub-centering won't work no more cause the hubs taper down from the flange out, so it will have to be lug-centered, but they are not coined like Dodge wheels are.
I seem to recall Chevy dually wheels are lug-centered, but they still use plat flanges like our trucks do -
What will you do for the front then, use the matching front axle off the newer truck?I was thinking more along the idea of a Dodge Dana-80, or, better yet, one from a later model F-450 with the BIG hubs and 19.5 wheels; I have laid eyes on some of both types available for sale, but am holding out for a 3:55, whereas all I have found for sale have been 4:10s and 4:88s.
Ah, so that's where the coined plate I'll be using when building my spare wheel carrier came from - I always wondered, I found it in a junkyard and took it, and now I know what it really is for. In that case, I have a question - if a Chevy coined plate is slipped onto a flat-face hub flange (provided it clears the hub one way or another) will that allow coined wheels to be used on that flat-faced hub?Actually, Chevy has used the exact same wheel configuration from about the mid-sixties right up to present day.
Chevy DRWs are flat-faced TIGHTLY HUB-CENTRIC, so tight in fact that often a sledge-hammer is required to knock them loose; BUT, curiously, Chevy uses a "coined" plate on top of the wheels and CONICAL NUTs.
With Chevy's hub-centric wheel, there is absolutely no reason they couldn't use flange-washered nuts instead of the plate/conical-nut system.
Not true for the 8 on 6.5" lug pattern Dana 50 and Dana 60 Ford axles - the dually hub is different from the SRW hub, same situation with the late '80s and early '90s Dodges, again hubs are totally different. Newer Dodges are done in the manner you described tho, and I'm not sure how newer Fords and Chevys are.Almost EVERY DRW 4x4 front axle is nothing more than a common 3/4-ton SRW axle with three- or four-inch spacers bolted between the SRW hub and DRW wheel.
Even the conical nuts that hold these spacers on are the very same ones that would hold the SRW wheel, yet they use the DRW studs and nuts to mount the DRW wheel.
With Ford pickup trucks tho the springs are already very close to the frame rails, no way you can gain 2" of extra clearance even if you put he springs right against the frame rails...As far as converting a pickup to a dually and still using the narrow axle, you'd have to move (tub) your wheelwells to clear the inside tires as well as inboard the springs. If you move to a flatbed, all you have to do is move the springs.
I just load mine down with sand, no way I give up my two on-the-ground spare wheels for just a small amount of traction. Snow is not the only enemy tho, wet grass is evil too, and wet grass on top of muddy soil is the absolute worst non-winter nightmare for a dually.Although I love my dually for heavy hauling and towing, one thing to keep in mind is traction loss in the snow...the weight in the back end is now distributed over 4 contact patches instead of 2...when running in snow with lighter loads I usually pull 2 off, makes a big difference
