Concerning DRW fronts, what I have seen and I see a lot, just about all 4x4 DRW front axles use the same axle as SRW but with spacers added; I often see these spacers for sale at swap meets; usually around $75-$100/pair.
With a bit of lathe work, these same spacers can be employed on the rear axle to allow for duals; .
The set i have will just slip over a dana 44 hub. They would need boring to fit over a dana 60 hub, and lose strength. They would need to be bored even larger for a rear hub - either becoming 2 pieces or paper-thin.
Edit: an axle truss wont improve the leverage problem at the hub bearings.
