highest_vision
Reqistered User
First up, the machine shop dude put my heads on the belt sander. IH says no surface work is to be done to the head surface. Am I screwed? I don't know why he did, he couldn't get .004 to go anywhere and they weren't warped.
The heads I took off my truck (I have four) have grooves in a few places where the fire ring ate into the head (this may explain the belt sander and I hate to see what I will find on the deck). My head gaskets were coming apart, so apparently that ring had been moving for some time. I had a known compression leak between cylinders, and this is where one of the grooves is. Any thoughts?
What is the ********* ring in the head gasket kit? Foamish, about 2" OD, maybe 1" ID, 1/2" thick.
Last question is regarding valve stem oil shields. Read a bunch of archival stuff somewhere but didn't really get a definitive answer as to whether or not intake valves get shields.
Thanks
James
Thanks
James
