Also, you should need a puller to remove the yoke, if you can slide it off, replace it or be prepared to go at it again soon (very common problem on 8.8's, they wear the yoke and splines of the pinion).
Check the slinger (looks like a big shim) that goes between the yoke and the rear bearing, see if its shredded down
And a few reference pics (there from a D60, but same info)
The "-1" tells us that the nominal distance is -.001" for the pinion shim
Each gear-set is stamped with an identifying “set number” on both the pinion and ring-gear. (327 is this one)
And a shot of the ring gear markings, at the far right (a bit hard to see) has the 41 10 (4:10 ratio)
lots of info here for setting up gears and a good read too
http://www.pirate4x4.com/articles/tech/billavista/Gear_Setup
