Got the tilt column with mint turn signal switch and stalk, working hazard switch, and these bad ass 1934 emblemns from member "Stubborn Nut" on here, thank you!!
the tilt column is friggin just what i needed with my setup. In the up position it appears to be super easy to slide in and out, then drop it down for laid back ez cruising. These emblems will look really bad ass offset on the front grill and somewhere on the back side of the flatbed on the 4" c channel.
So nice to have a column with a turn signal stalk that doesnt fall out! (mine was stripped and if you hit a bump the stalk would fall out..right before I needed to make a turn). I am wiring my stock hazard switch to the aux strobe lights that will be being put on. Not sure where I will need them..but I want them.
