LCAM, for the starter solenoid trigger, the post itselt is tiny, takes an 8mm wrench for the nut. I believe the relay just sejnds a bit of current thru it to the solenoid which then uses the heavy 3/0 cable from battery to starter directly.
For feeding it 12v, i just need any ol key on 12v source right? This is a trigger wire so very little current goes thru it.
Nice thing is the fuel pump and coil wire I have are hot while cranking, and my starter trigger works, so today i jsut gotta route the wires and hook em to the relay triggers. The glow plug relay is simple then if I follow LCAMs suggestion. 12v hot on one post, 12v switched to the glowplugs, and 12v trigger wire to the S terminal. I need a battery post with a longer stud lol.
Question regarding fuses. Should I fuse my glowplugs and alternator? I have those blade fuses from 180 amps to 450 amps. I was thinking of running a 175 inline with my alterantor charge wire (1 wire 150 amp unit). Same thing inline with the glowplugs?
heres some quick pics from yesterday.
tickest glow plug harness out there i thinks.
10g orange leads,
8g black branches
4g main feed.
dielectric grease on all the connections, 3:1 adhesive marine grade shrink wrap. I used my Tenco hammer lug crimper to smash the insulated 6 and 4 a3wg butt connectors because i dont have hand crimper sbig enough. It is a super solid connection.
really. grounded. relays. Plus i will run a cable from the plate to the negative terminal as well. I got a large 1" braided strap from block to frame, battery to frame, battery to block.
doubled up 2/0 cables to the starter 2/0 cable alll around for + and - from batteries.
I have since turned the relays 90deg so the S terminal i sfacing up. easier to conect the 4awgs this way.
first time i feel confident in my wiring. everything is so gaddarn protected and sealed it can practically live underwater.
all my lights and other things are on weatherpack connectors. (well, will be. i dont have time to do those right now im leaving extra wire, and there are jsu ton shielded m/f spade connectors).
