i got from 8 am to about 530 pm on saturday to get some serious work done on the cab. Got more family coming over and I promised Id show em around while theyre still a little bit of daylight left. Life...gets in the way of real life (building trucks).
Today I will attempt to finish the other side B pillar, and at least the one cab corner (needs a tiny sheet of metal, other corner needs to be made from scratch). Once THATs done, i can put the bench iun, drill my locaitng holes, and flip the thing over and finally stitch weld and seam seal!!
question. Should I undercoat THEN seam seal, or seam seal then undercoat? Im concerned how that seam sealer will bond to bare metal. Im thinkign if somebody scuffs their foot on the floor, will it lift the seal sealer? But also thinking, that if its seam sealed, then 10-12 mils of undercaotiung film laid on top, it woudl create a blanket of sorts over the sealer?
I mentioned earlier in the thread, I am using hy-tech Metal Shield for the underside and top side of the floor.
get that engine in there, get some mounts going for it, then i can position the trans in, and know for sure where i stand.
