jhenegh
Truck Still Earns its Keep
Over the past year my truck has gone from no significant oil consumption or oil out the draft tube to about 2 quarts per 500-700 miles. I think most of it is out the draft tube but there is no for sure way to know that. My draft tube is a 1" hose off the valve-cover mounter CDR to out under the truck. It used to have just a slight bit of blowby out the hose, even when warm & towing, and didn't coat the bottom of the truck. Now the bottomside is covered in oil (rust-proofed? ) behind where the tube exits at the end of the cab.
I used to do 5k oil change intervals with Delo 400LE and a powerstoke filter. When I went to change the oil this fall, the oil that came out after 5k was terrible. Sticky, and much more tar-like than it had ever been, like it had been in there for 15k, not 5k. It stained my hands and clothes like I'd never seen before. I added a few quarts along the way, and during this interval is when I started noticing more blowby. I dumped in fresh oil, ran it 500 miles, changed it again, and have now gone 2000 since and plan to change it again here soon.
This truck is rarely driven unloaded anymore, and does a fair amount of towing heavy. This was a shift in the last 18 months, and I'm worried I went too long on that 5k interval while towing basically the whole time and gummed some stuff up and basically put on a bunch of internal wear, especially on the rings it seems.
Pictures are for reference of the truck's duties. A few loads per month max, but it is the designed towing vehicle around here. Any ideas or experience with something like this?
