Well, it don't look like much but I've been busy most of the day.
I pulled the pulls off the ps pump I'm using. Here it is next to the one I removed from the truck.
Notice there is an extra 1/2" or so there where my finger is pointing? That's where the custom spacer (nut) was on the other one.
So I got a tub of diesel on the table to degrease stuff. It works okay. I gave the ps a quick brush off with fuel and it looked good. I was going to give it some fresh paint so I hit it with a spritz of brake clean. Bad idea.
Blew the paint right off. So I stripped it and will paint it now.
Box of degreased parts. Ready for some soapy water and blasting.
AC compressor and bracket. I pulled the bracket off and scrubbed the compressor down. It looks okay. Not going to much trouble on it until I'm sure it works. System had pressure but it wasn't hooked up so I don't know if it works.
Tore the fuel filter head down to delete the heater and clean it all up.
Pulled the center section. Heater pops right out.
No wonder this thing leaks.
And top view for reference.
Water pump bolts laid out.
Thermostat water neck with check ball.
Non motorcraft thermostat.
Water inlet.
IP and lines.
Gear cover and gear are in the solvent.
Rolling along pretty good then found this.
Damn. It gets better.
So now I have one broken ear on each exhaust manifold. These things are thinner than I thought. What really ****** me off is I spent all this time getting the turbo to fit the banks and stock plumbing. If I had known both manifolds were bad, I probably would have done things differently. [emoji20]
I pulled the oil cooler off and it looks okay through the muck. I'll clean it up and see but I've got a spare set of headers.
Continued.
