Minimal update. I took tonight and inventoried some parts. Started digging through my box of ziplock baggies to see what I had. After making a list of the next bunch of money to spend, I dug out my front tank sending unit. It needs cleaned up. The rear was trashed so it will be taken from the parts truck which has one in good shape I think.
I ordered a bunch more stuff this morning so I'll have plenty to do this weekend. Should have everything to complete the brake system up to the master cylinder. If you want Wagner brake pads/shoes do yourself a favor and get them from Amazon. Less than half $$$ what advance wanted.
So all that aside, I realized I left myself a little present. I forgot the front tank skid plate bolts on the frame side broke. [emoji35]
The front wasn't too bad.
Easy access. The a$$hole who thought it was a good idea for them to poke up through the crossmember on the rear ought to be shot.
One of the clips cost me a hole in a finger. [emoji35]
Anyway, cleaned it up with some sand paper and shot a little primer on there. This was the reason for using the implement enamel but I have to say, even with the hardener in it, it's way softer than I would like. But too late to change now.
Dug out my fuel tank straps but I'm going to see what they cost. I could clean them up but let's face it, this is no longer a budget build. I'm in get it done mode now. I don't even want to know what I've spent this week but all necessary and it'll push me quite a bit farther along.
as long as its just a hole in the finger, and not a hole in the head, youre on the right track!
if you dont put your blood sweat and tears into it, she aint worth building!
