Well, I somehow got lucky and didn't have to work the entire weekend. After a 60+ hour week. After a trip to the depot and a little help from some folks here I got the fuel tank bolted up. That leads me to the next quandary.
Here you can see the FSV and the location of the sending unit. Question is how do I get from one to the other. Since I relocated the FSV, it makes the front lines longer than they were. There is not a ton of space up along the frame rail and I still have a wire harness to run up through there. So as I see it I have 2 options. I can run hard lines with soft connections like I did for the rear, or I can run hose all the way. The hose would be quick and have no extra joints. It would take up more space and be a little harder to mount. I'd probably put wire loom around it and zip tie it in there. If I went hard line, I'd probably take the stock plastic clips, cut one of the three holders off making it a 2 clip then do it with the bubble flare like I did the others. Not sure yet. I want to get this done though because this and the trans are the last bits keeping me from setting the cab back on. Guess I'll sleep on it.
