So yesterday I spent basically all day (well all garage day) working on the back half of the truck.
I filled the diff. Tipped it both ways refilling after. That was a fortune in gear oil. Sheesh.
Then I started at the back with the torque wrench started going over everything.
Hitch
Shackle bolts
Front hanger
Shocks
Carrier bearing mount needed lock nuts installed.
I hit the u bolts with the ratchet and drew them down even as I could using a tape measure to measure the bolt sticking out. I started with the torque wrench. Took them to 110. Book calls for 150-210 on f350, 75-100 on f250. They are 9/16 ish u bolts but it was a struggle to get to 110. It just felt funny. It's probably just compressing the springs. I'll go over them again after I drive it and make sure it tracks straight. The axle won't fall off suffice it to say.
I started poking around and I found a spot I'm going to have to address in the paint but I'm not going to show you where in case I don't get to it.
I popped the hood as I was making a shopping list and I discovered I have at least one clearance problem.
The oil line is touching the hood so I need to figure out a different way to tap in for the senders.
Today will be more of the same probably. I'll likely tackle the front axle. Got to decide what I'm doing for a cover so I can seal it up and fill it.
