Alrighty. So close to having a complete drive line. Picked up driveshaft. It fits perfect. I'll snap a pic when I tighten the nuts on the carrier bearing. These guys seem to have done a decent job. Said he had to straighten the rear tube a touch and I see a tell tale heat spot on the front one two. But it has a fresh spline shaft with blue coating and carrier bearing. I had a heck of a time getting the slip joint together. Man is it tight. Like I said fit seems perfect. So I turned attention to the front. I needed to put the new nut on and torque the pinion nut. Couldn't get enough oomph on it without moving the truck. Hmm. So here is the torque wrench and multiplier.
I jacked it up so I could set the rotation of the nut. Then used my truck bed load shift bar to hold the brake.
Ratcheted right down. Broke it over at like 265 ft lbs. spec is 240-300. Lick of paint on the yoke and call it good.
Assembled the front shaft.
It's ready to go in. Just need to figure out what freaking straps I need for the yoke I changed out on the front. I've tried twice and struck out. That's all I lack of having a complete driveline.
