Project Big Red
laserjock
Almost there...
Well, the 3.5" V and flanges were a failure on the exhaust brake. [emoji20]
There's no way the V band will work. Back to the drawing board.
subway
be nice to the admin :D
York PA
If you need a gage cluster let me know I might know where one is.
Sent from my SM-G930P using Tapatalk
laserjock
Almost there...
Thanks a heap!! I'll let you guys know. I suspect it's a ground problem. It worked when I pulled it. I think pretty much everything in the cluster worked. What didn't work was the lights. Now they work and the cluster is dead. The fact that nothing works screams it's an electrical problem. Would be pretty odd for everything to die at once.
Need something to go right today.
laserjock
Almost there...
So I have been fighting with the cluster. Summarized here:
http://www.oilburners.net/threads/electrical-help.79527/
The situation has improved. Part of my problem was actually a BUNCH of burnt out bulbs.
Right now the tally is functional:
Left turn
Right turn
Seatbelt
RABS
Illumination
High beam
All the gauges
Heater controls and blower
Cargo light
Parking lights
Hi and low beams
Not working:
Check engine
Engine
Charging
4x4
Low range
Brake warning
So that's progress I guess. The high beam was my stupidity. The indicator actually ties in out at the DRL harness which if you were keeping score, I nuked. Manual says it ties in at the foot switch. Nope. So I tied it into my harness for the relay mod. All better.
I know am powering the cluster correctly. Not sure why. I changed fuses and tada. Old fuse tested good. Got me what actually changed.
So now I need to look at what's working and go from there. I suspect those may be problems out at the senders but I really don't know. All the indicators should self check on Key On power like the RABS is right?
Now It won't start with the key again. I'm not sure what that's about. I adjusted the ignition switch but no love. Lights dim like it's trying but no love. I put the charger on it. Maybe the batteries are a little flat with all the key on time etc. oh well. That's for another day. I'll probably order a new switch while I'm at it and it's easy to change.
Anyway I think the plan now is to keep putting things back together. Going to make some calls to see what the driveshaft is going to cost me.
I put the transfer case shifter in. That was not easy. I can't get it to shift. Probably need it to be running to get it to shift.
Still have to figure out the exhaust brake thing. I may have to make flanges.
Anyway, that's it for tonight.
subway
York PA
As far as the fuse goes into have run into them where they are cracked. They connect enough to check out ohm wise but won't pass any amount of current through them. They can be a pain to track down.
F350camper
BOOST!
USA
Is your clutch switch acting funny on this one? I know my 92 use to before I fixed things up. Had to have the pedal really mashed into the carpet to get it to light.
laserjock
Almost there...
I currently have it jumped. I suppose it's possible the jumper came loose.
laserjock
Almost there...
So I got the truck starting with the key again. I had chased wires and came to the conclusion that it had to be the ignition switch. New ignition switch, same thing. So I started at the solenoid and started working my way toward the key. Put 12v to it anywhere I could get to it. I got all the way to the clutch safety switch and 12v kicked it over from there. So in a fit of frustration I reached over and hit the key and it cranked.
LOL
Honestly I have no idea what the problem was. I suspect the transmission harness that has the jumper on it where the auto neutral safety switch would go. So now I have a new ignition switch and a couple old ones that are probably fine. [emoji849]
I think I have a solution to the drive shaft issue. Picked this up tonight.
It is not a factory piece. The giveaway is the slip joint is different. It looks really clean and has been balanced. It was in an E4OD truck. It is really really close to the same length as mine. The front section looks to be about 1/4" longer than mine. The rear is really close to the same. I'm going to stick it in and see how it fits before I tear it down. Fingers crossed it's a drop in solution. Even if I have to have it trimmed, I'm far better off than I was I think.
Still need to figure out if the front shaft will work. Does the double cardan joint take a different yoke on the tcase?
Anyway, I think I'm about ready to finish putting the front end together.
my understanding is that the cardan is for the straight axle.
I could not find a 1330 CV yoke anywhere!
I took a rear slip yoke with the same splines had to bore the center so the nut would fit
then trimed the end to the correct length.
I did purchase a 1310 CV yoke that don't work lol
but the TTB don't use a CV(cardan)???
laserjock
Almost there...
Okay. So my truck is a SAS f250. I have seen reports both ways as to the drive shaft bolting in or not. So you convert the tcase to slip yoke? Didn't the drive shaft have a slip joint already? That seems peculiar. Oh well. I'll figure it out.
completely missed the SAS lol
my bad.
yes, that's a slip yoke, but has been machined to a fixed yoke.
it don't slide on the front output shaft, its bolted on, and yes the front shaft has a slip.
subway
York PA
When I pulled the drive train out of my solid axle F350 it had a double cardian joint with a different yoke specific to that application. The yoke ears are taller with a deeper valley to allow clearance for the double cardian joint. Towcat snatched it up for those reasons when I was selling off my other stuff. Apparently those yoke are rare and you can't buy them new anymore.
Sounds like Brian found a work around.
junk
Paullina, IA
I've always used an f250 shaft in my f-350. But I've also had a US gear in there so my front drive shaft is really long. I've never had a vibration or excelerated u-joint wear with my setup.
laserjock
Almost there...
Front driveshaft seems to fit perfect.
Plenty of room to the crossmember. Angle seems really reasonable. This will be a clean paint and install with new joints.
The rear looks like it needs to loose between 3/4"-1". I'll call them tomorrow and see what the deal there will be.
I am officially on the clock with rally reservations made. [emoji15]
