leftcoastjeff
Frankentruck lover
As some of you know, I recently replaced the oil cooler orings and replaced the entire unit (thanks Towcat!!). what a major PITA, though the next one will be easier.
No leaks in or around the cooler, but a small puddle of power steering fluid has appeared, I tightened the high pressure hose and it slowed it down a bit.
That's not good enough for me!
I read that the hose has a Teflon washer on it, not a oring.
Do I need to replace the hose? really? crap!
I'll call around tomorrow, unless there's a fix.
Thanks in advance,
LCjeff
Thanks in advance,
LCjeff
