Power steering fluid leak
leftcoastjeff
Frankentruck lover
Monterey, California
As some of you know, I recently replaced the oil cooler orings and replaced the entire unit (thanks Towcat!!). what a major PITA, though the next one will be easier.
No leaks in or around the cooler, but a small puddle of power steering fluid has appeared, I tightened the high pressure hose and it slowed it down a bit.
That's not good enough for me!
I read that the hose has a Teflon washer on it, not a oring.
Do I need to replace the hose? really? crap!
I'll call around tomorrow, unless there's a fix.
Thanks in advance,
LCjeff
f-two-fiddy
Duluth, Mn.
The high pressure line has a tapered fitting. No o-ring. So You might as well just replcace the line. The return/low pressure side has an o-ring seal.
leftcoastjeff
Frankentruck lover
What?
Seems to me that the low pressure line is a rubber hose with a band clamp. :dunno
It's on the bottom of the pump.
The high pressure side is a hard line connected to a hydrolic hose, seems to me I saw an oring on there, then maybe I'm mistaken. cookoo
It comes out the side of the pump.
Are we talking about the same critter? :dunno
LCjeff
LCAM-01XA
my very own hell
A new hose is about $25, if that - I'd think it's a cheap insurance against potential trouble with the old house (blowing it up really).
DragRag
Los Angeles, California
I have a 94' frame that has the powersteering unit still on it here in hollister. If you want any of those lines, just come and take them off the truck n/c. Pass on a favor when you can. Just let me know if you want to come by, I am a stones throw.
Dsl_Dog_Treat
Decatur,MI
Napa shows 2 orings with hose $20.00, Ford says teflon (one time use)$3.00
So I'm off to Ford
LCjeff
You can get the teflon rings?????:hail
You da man.
I can't seem to locate em round these parts.:dunno
Iv'e got a leaker too and that's the problem.
leftcoastjeff
Frankentruck lover
teflon ring #
From the invoice,
" *388898*S Seal $2.05 + $0.19 tax" for Arnold.
Let me know if I can be of service, I'm less than 10 miles from Ford and another 30 miles away. (truck specialty)
Now to install the hard teflon ring, the parts guy at Ford said to warm it in water to expand it a little to ease installation.
We'll see,
LCjeff
PS please add the oil cooler orings as well while your at it,
From the invoice,
Big one, 1C3Z*6K649*BA
The smaller one, 1C3Z*6C610*BA
leftcoastjeff
Frankentruck lover
SOS
Same old s#$%!
The white ring is the one I got from Ford, the black one was on the hose.
Replaced oring, no more leak!
When I called Ford they said that there are 2 types, they would be happy to refund my $2.00 and they have a drawer of orings I can dig through.
My neighbor had the proper size oring. cookoo
And yes there is a small cut in the old oring! :sly
If anybody needs this teflon ring, it's yours!
LCjeff
sassyrel
iowa
you lucked out!!!!!!!!!! most of the time--right where those rings go---is where the dang line cracks!!!!!! been there once tooo often--and tightening that type line--does nothing--way diff than the old style lines---
leftcoastjeff
Frankentruck lover
Doh
Upon further inspection, it seems to be leaking less, we'll see.:dunno
I can't get to the band clamp on the return line, otherwise I'd check it too. cookoo I may have to remove the pump to get to it
LCjeff
Seven4eight
