TDI
Hello,
I just installed a Conestoga Diesel baby moose pump on my 1985 F250. The pump is awesome and unless I did something wrong, the installation was smooth and easier then I expected. I have a pyrometer and water temp gauge to install, that may be harder for me to install than the pump.
Removing the old pump went smoothly. When I installed the new IP I did not do it with the hard fuel lines on, I wanted the new pump to slide in smoothly and squarely without having to wrestle it in place. You can install the lower two fuel lines first but the others I would leave off and install one at a time after the pump is set.
You need to install the top center mounting bolt on to the stud when you partially slide the pump into position, after the pump is fully seated you cant fit this nut on to the stud, that explains why mine was missing.
Starting the truck with the new pump went well, cracked a few fuel lines open at the injectors and it took 40 seconds of cranking to fire up the truck. It ran at very high idle RPM's but then settled down after three minutes. The idle is still noticeably higher and the truck is louder. I am not sure if my partially broken accelerator cable is contributing to the problem or if I installed the return springs correctly and they are hanging up on something.
I ordered a new accelerator cable, I'd like to time it myself once thats installed , but how?
QUESTION ON TORQUE AND SMALL PARTS:
I may have over torqued the three 16 point bolts that hold the pump inside the gear housing - should I re-do this??
The CD baby moose pump came with an O ring and a small steel rod about 1" long, where were these supposed to go? In the heat of wanting to finish this job I failed to stop and call Mel or ask here!!
Thanks.
Thanks.
