LCAM-01XA
What's the chance of high-centering this truck? If you think it's fairly likely, then having the pipe as low as it is now won't work in your favor when the event happens. If on the other hand you have other stuff that hangs lower, and that stuff will be the first to make contacts w/ whatever it is you're running over, then you can leave the pipe as is. Only you know how you gonna use your truck, only you can make the call. Personally I'd have it tucked up high and away from danger, then skid the transfer case real nice and know that I can safely run over downed trees and such if the need arises.
