MUDKICKR
i guess if everyone would rather insult it then read the description, i will post it.
Up for auction is my custom 1991 FORD F350 DUALLY, Stretched, 4X4, CREW CAB, EXT. CAB WITH 4 WHEEL STEERING!!!!!!
NO RESERVE
8 inch lift springs, new 355-80-16 (38.5x14.50) procomp xterain tires, new aluminum rims
7.3L non turbo diesel, automatic overdrive trans, dana 60 front axle 3.73 gears. dana60 rear axle , 4.10 gears (1 ton dodge front axle converted to have rear steering)
the rear steering is controlled by electric toggle switch on the drivers door, and can be turned off and locked for street use.
the frame has been extended to add the extended cab to the body, making it like a limo,with lots of room in the back seat.
the engine runs and drives, but is leaking fuel from some o-rings.(its been sitting for awhile) and will need to be resealed.
the sun roof needs to be sealed,(leaks)
THIS IS BEING SOLD AS IS, WHERE IS, AND WILL BE THE BUYERS RESPONSIBILTY TO PICK UP.!!!
please ask qestions if you have any, and i will answer them each night.
THIS TRUCK TURNS HEADS , AND ALWAYS GETS ATTENTION!!!!!!!!!
THANKS FOR LOOKING, CHECK OUT MY OTHER ITEMS ON EBAY!!
im guessing by the switch for turning that you turn the rear independently.
NO RESERVE
