Hello all, new guy here. Done plenty of reading on this site as a guest, I just recently bought a 1990 F350 7.3 IDI Non Turbo, 5 Speed, Quad Cab Long Bed, RWD.
I was able to find it on craigslist for a very reasonably cheap price given it only has 100k miles, and had always wanted a diesel truck. I'm also a bit of a ford nut, I now have 3 of them. I also have a 1990 F150 with only 42k miles (was my grandfathers, T18 4 Speed, 4WD, 300 straight six short box single cab), and a 1989 F250 (Titled as 150, its kinda a mash up, previous owner did a lot to the suspension, 300 straight six, 5 speed, long bed single cab).
But anyways, I had take some time off from work and done a lot to the diesel, changed the return caps and lines as a couple were wet and changed all the o-rings. Changed the fuel filter, changed the oil, changed the transmission fluid, flushed the anti-freeze after reading all of the cav articles that scared me half to death, fought with tractor supply trying to get the correct fleet antifreeze and not the wrong type they tried to give me when I went to pick mine up. Everything was going very smoothly even with the minor repairs that I felt I needed to make after trying to do my homework. I'm far from a mechanic but I can follow directions and have tools and generally can do some things. Grandfather owned a mechanic shop for 40 years and I spent a lot of time watching as a kid.
Now I'm driving home the other night with my girlfriend from the mall, and all the sudden at idle it feels like I'm in a washing machine on a spin cycle. Real bad shaking, felt like my old case farm tractor running on 3/4 cylinders at warm up. At speed it went away, at first I wondered if it's just some leftover bad fuel as the truck had more or less sat for 3 years from previous owner but we get home and its starting to shake pretty much non stop with the motor rotation. All I was thinking is they have a dual mass flywheel and I don't want to get involved in that whatsoever. Well today I went outside to try and figure out if I could notice anything else as a friend had said it sounded way more like a fuel issue to him and the shaking wouldn't be that severe from a flywheel issue and the truck still be driving normally / clutch and transmission operating totally fine, and sure enough there is the problem right in front of me.
The line from the fuel filter system going into the IP is leaking like a sob. I'm surprised the guy drove me home and started today in below freezing temps quite honestly, because the injectors can't be getting anything close to an even distribution of fuel.
My issue is, from a quick search I can't seem to find anywhere online that has this line. The others all "seem" fine and I wouldn't mind replacing all of them either, but I wouldn't mind starting with just this one and going from there as I have my car and other two fords to drive should another line bite the dust shortly after repairing this one. Anyone know where a good place to purchase one would be? I honestly didn't even stop at advanced auto parts / autozone yet to see if they have it, but I don't have much faith in my local stores after I went to get a kit for my return lines and caps and the guy brought me out injectors. Haha.
Also, I don't suppose I can give this whole story without at least giving you guys one picture. I need to take another one on my phone of just the new diesel truck however, but you can get the idea. Any help would be greatly appreciated, I'm gonna keep looking around online and possibly stop at advanced on my way to work today anyways.
