input shaft seal leaking
dmaxjoe
Mount Morris, Michigan
91 zf5 trans fluid all over clutch. I pulled it back away from the engine and it seems to be coming from the input shaft. Can that seal be changed from the out side?
dancrowley
danc01
south of Boston
ZF input seal
No, I don't think so because one fits over the throw out bearing sleeve and one fits inside the sleeve which is inserted from the inside of the case. Dan
m2rtin
