flatlander
plays dirty when losing
7 psi at idle 6 psi at WOT.
stage 1's going in tomorrow AM. New report then.
stage 1's going in tomorrow AM. New report then.[/QUOTE
damn u actually got the stage 1's did you do mail order or did you pick them up yourself i mail order mine dps just couldnt figure out how to get them shipped out to arizona
funny thing is that im still pissed off at dps for screwing me around for 2 months
sorry totally off the subject
Hmm, would have figured you would have picked up a little.
Hey, can you quickly explain your turbo setup again. I've always been under the impression that its not your normal run of the mill twin turbo setup. This is what I think of when I'm thinking twin (er sequential) turbo setup. You have a small and a large turbo. Exhaust goes up into the small turbo, and exits out of it, and then goes into the large turbo, then out of the downpipe. The small turbo spools up the air from the air filter, then forces it into the larger turbo, to be boost more, and then sent into the intake. Its not setup like that is it?
So is this how you broke your drive shaft?You're half right. The exhaust is just like you said, but the air goes the opposite way. It goes through the larger turbo first, then the smaller and into the engine.
Ok, I gotta know. How you keeping those EGT's so low?
Ryan
You still need the one I got? I'll be pulling it after I get the grass cut.
You might be a redneck if you have to cut the grass to get to a driveshaft
