I know you are busy but I hope you can take the time to give me a little more advice on the head swap... Heads are off an OB member donor 7.3 with 200k. They are going on the chuffer 89 SC.
The heads have been cleaned and pressure tested... They passed pressure test although I don't know how the test is administered or what value the information has. I am picking them up this week and replacing springs, seals that Typ4 provided. The Felpro gasket kit has head gaskets, valve cover gaskets, exhaust mani gaskets, and new copper injector washers. I got the Felpro valley pan with grommets and sealer.
If the heads passed a pressure test do I still need to lap them? I don't really know what the pressure test tells me or if the information is valuable.
Heath's advice was to spray Hylomar on the head gaskets, what do you do?
I have about $200 to spend on parts/tools for this project. A torque wrench, hylomar, and a 1/2" thread chaser for the head bolt holes, return line kit possibly the lapping kit if necessary. I am strongly considering buying a single set of head bolts in case one or two look iffy. Is there something else I need or something I do not?
What needs to be done to the block face to prep besides gasket scraping / cleaning? Are some level of nicks, dents on the piston crowns okay or completely unnacceptable? I have the chuff and I have a feeling there may be some damage. Engine is still in truck and will remain.
The heads came partially disassembled with the rockers and pushrods separate. The wear on the rockers all looked the same except for one where the little rectange wear mark looks more like a triangle. Rockers and pushrods were not with the corresponding heads so I don't know which goes where.
BACKGROUND: The $200 is all I got and the chuffer is my daily so I don't want to wait any longer to do this job for fear of being left with no wheels. This truck will be pulling a mowing trailer almost daily and plowing snow. Mowing season starts ASAP.
