93turbo_animal said:I know of 4 OBS that when you rev it up it has a cough to it and I'm sure that theres nothin wrong with at least three of them and I read countless post about it from new truck owners cause it will smoke a little when it does it and they think somethings wrong I guess you got the one of the odd balls that don't or your talking about running at 2200 rpms and I meant just reving it up![]()
first off a skip/miss ina psd is not normal.this is usually caused by bad injector O rings.it might nedd an oil change.the wrong type of oil could have been used in it.another issue with the 94-97 trucks is that they had the wrong dipstick for the oil.some had a dipstick that read full around 10-12 quarts when it takes 14 quarts.aerated oil will cause a skip.
im also willing to bet that on these 4 OBS you speak of have probably never had the fuel pressure regulator screen changed.smokeing associated with a skip is also caused by bad injector O rings.
http://pages.prodigy.net/stevebaz/_import/pages.prodigy.net/stevebaz/index3.html read this.it is the powerstroke bible.
now if youre considering an SD you have to be completely honest about what you plan to do with the truck as far as added power cuz there are a few years to stay away from.
