Rdnck84_03
Ok that up close picture it looks more normal. It definitely should be turned around the other direction though. I'm really not sure what is going on if it doesn't work turned around the other direction.
All of the zf transmissions I have dealt with seem to use the same shifter. I guess it is possible there could be different variations out there though. I have currently have 6 different ones ranging from an 89 small block zf5, a couple of mid 90's big blocks, a couple of mid 90's diesel and a 01 zf6. The shifter stub is the same across all of them.
James
It's a unicorn.......All right, pulled the shifter itself out of the top of the trans and it looks very different from the one pictured above. The ring for the boot to sit on is much higher up, and the shaft almost seems longer. See a part number on it too but I can't make it out perfectly. Looks like ZF 1308 305 177.
Does look like it'd be fairly simple to bend, so that is still an option. Any chance I can get the link to the shifter from above? Thanks
