I know cummins 12v engines can make a lot of power like 800 or so hp and still be driven daily what about ford IDI??? Dont they have that kind of potential or what. My dream truck would be a ford F250 or 350 crew 4x4 with 6inches of lift, and lots of power, If I want this do I have to put a cummins in my ford.
OK so Two minutes later you post this in the Marketplace forum,
Hi, I have my 88 F250 xl superab longbox 4x4 ZF5speed over 8,800 gvwr, so I think it is a heavyduty, 10.25 ford rear tbb dana 50 front, 3.55 gearing, truck got 20mpg on highway at 1,700 to 2,000 rpm, some rust along the very bottom of the cab but truck is 90% rust free, frame has no flaking only dark brown in color or black. I beliveve truck has 100k miles due to previous title from Wisconsin saying 69k actual miles back in 95 but not sure. Truck started hard but now Ipump is shot and I burnt up the starter solinoid. and I took the Ipump off without pulling the gear off so I disturbed the pump timming, so dont know if it will start again if I pull start it, and I am out of money and have no job to get new parts for this truck. Before I took the I pump off the truck when it started ran great would rev to the red drove up to about 95mph just twice to see if it would do it, used about a quart of oil every 200 miles on the highway had a some blowby out the oil fill but ran great, 4x4 works everthing else worked ok. I would like to sell this truck for $900 OBO I have pictures email [email protected] or you can call vince at (906)789-0761 or on weekends (906)241-0028 Truck is in Escanaba in the upper peninsula of MICHIGAN
It appears to me that based on your obsession with Power, your lack of experience, with diesels, (I to lack diesel knowledge, though I have wrenched gassers for many years) or auto mechanics in general, that some bad choices where made that have led to your present position.
Why not get a job, keep the truck, hang out here and read read read, then read some more. Did I mention read? All the while working towards affording to repair the truck you have and get the most out of what you have.
When you are in a position to buy Big Power because you have worked or some how got money, you can do so and hopefully by then you'll have read enough along with got your truck running well to objectively make choices based on reality rather than smoke!
Take the time needed to learn all you can before you "dig" into things that perhaps at this time are beyond your current skill level.
Just an FYI it took 7 months of research for me to actually make the decision of converting my 90 Gas engine Bronco to a diesel engine.
That included posting questions here, talking to Jason a diesel mechanic, who owns a 6.9 with turbo. Having him help me start the diesel engine and get his opinion on if it would be worth purchasing for a conversion.
These trucks are well built, require simple routine maintenance and will last a lifetime or two if well cared for.
Take some time to re-evaluate your situation then take the steps needed to change what needs changing so you can have the vehicle you want/need based on reality not Numbers of HP or TQ....Base your choices on education and reality not smoke and dreams.
