exhaust brake idi ideas
69dieselfreak
well that nice
rimrock arizona
exhaust brakes is the question would we have to buy one from like banks and make it fit to our trucks is anybody interested in this concept
FordGuy100
Silverton, OR
I heard it was a bad idea. Because IDI's have Hydrolic lifterts and it would cause them to do something, mess them up somehow.
69dieselfreak
well that nice
rimrock arizona
youd be using exhaust back pressure to slow the engine down i dont see how that would hurt anything but then again im not that familiar with light duty diesels
tractorman86
Buckeye, AZ
i don't know i would be open to discussion but have never done anything with them. it sure would be cool to get one on an idi!
FordGuy100
Silverton, OR
Well I think it was something like this. The whole idea of an exhaust brake is to increase back pressure. But with hydraulic lifters, all that added backpressure puts a lot of strain on the valvetrain. This in turns leads to lifters to kinda go flat I guess, deflate, whatever its called. It had something to do with something like that LOL :D
69dieselfreak
well that nice
rimrock arizona
not nessesellary banks but exhaust brakes in general like jacobas bd and who ever eles this might be good for the guys who are pulling big heavy loads and dont want to F-up there trans or service brakes
69dieselfreak
well that nice
rimrock arizona
are you thinking of a jake brake (compression brake) witch with the exhaust valve is held open via oil psi letting the compression stroke go out the exhaust
NCheek
Howdy
College Station, TX
BD makes a generic exhaust brake that can be welded onto the exhaust that would work for our application, but I heard that that it is tough on the valvetrain...
Best guess is talk with the manufacturers and people who have personal experience (not hearsay) with them on a 6.9
FordGuy100
Silverton, OR
Yup, thats what I heard to ;Sweet
Agreed, I've seen someone on here with one, hopefully that person will chime in ;Sweet
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
I have a US Gear on mine, I'll see if I like it. Basically, we have 100lb valve springs and with enough back pressure you can "float" the valves. I think the gauge that came with my set up(came from my donor truck) has a redline at 40psi.
punkmechanic
diesel tech
North East Portland Or
Just my two cents but I wouldnt run an exhaust brake. I was at work and found one in the "parts corner" (random pile of stuff that we have pulled off and set to the side for one reason or another, I use it as a stock room for ideas lol) and was looking at putting it on my rig. In any event I was strongly warned against it by the older wiser techs. Apparently it can (and as they said does and will) bend the pushrods.
the idea of an exhaust brake is simple, plug the exhaust and use the compression of the engine to slow the vehicle via engine speed.
The problem arises when you take a light duty engine that wasnt designed with these added (reverse) stresses in mind. we own those motors, all the 1 ton diesel are that way, not just idi's.
The limiting factors in the brakes (your pressure gauge, etc) will prolong the life span, but the simple fact is these diesels werent designed to run backwards and the valve train will take a beating with an exhaust brake installed.
just my two cents.
For years, I could come to almost a complete stop by downshifting. Then I wore out the syncro in my 1st gear, so if I decel in 1st, it pops out of gear. Morrow of the story.... brake parts are cheap and easy to replace. Now, I never downshift.
