placidoert
Have a 93 7.3 idk n/a parked it for the winter ran great half way to the shop then once I got there it started to run very poorly like it was missing on a couple cylinders would not refire up on its on with out a quick spray of either. Recently I took the truck out for the summer still running bad I changed all eight injectors I already had one go bad last year and now truck cranks and doesn't start and no smoke out the exhaust after changing injectors. Injection pump is relatively new has about 30k on it. Truck has electric lift pump have fuel coming out the Schrader valve when cranking and fuel coming out when cracking the Injector lines. I check the fuel shut off solenoid it clicks on and off when given power. Replaced fuel return line caps and hoses. Not sure if a bad Selector valve would cause any of this I know if you get air in the return system at all it won't run. I'm just lost with it any help is appreciated trying to go camping with truck in a week.
