Doing a d60 swap and one part missing
kpj
Finland
Doing a d60 swap and one part missing, FOUND ONE, no need anymore...
Well you probably guessed what part i'm missing, front driver's side lower u-bolt bracket. I've got all the other parts from a donor f350 other that sway-/trackbar brackets which a can fabricate myself, but no drivers's side lower u-bolt bracket. So my question is that do you know someone who happen to have one spare bracket? I would appreciate if you'd pm me about it, thanks. Second question, have someone attached front axle to spring similar way than it is attached in the rear axle. Why the front side needs to be attached differently than the rear axle :dunno.
kpj
Finland
Could you post a link? I searched their site and only found flat plates that they want you to modify the axle to use. My friend lost his plate, and if we have to cut the axle we can just make our own flat spring plate for less. Thanks!
x2, found it also and that ain't so hard to fab myself. For some reason i would like to install the axle with the original plate...
ntjapkes
