LCAM-01XA
I was thinking about that too, but I don't know if the Dodge hub extenders will fit over the Ford locking hubs. Our yard truck is an '87 W350 with a D60 and it has the dually-specific hubs that look much like those posted in that picture, but the locking hubs are those Selectro monsters are stick out of the wheel, unlike the Ford locking hubs that kinda sit flush in the wheel hubs - I know that later model Dodges with the hub extenders don't even have manual locking hubs, so I have no idea how much clearance there is inside the extender...In a search for true bolt-on DRW adapters/extenders, don't forget that Dodge used them on 4x4 DRWs on many year-models.
The factory removable hub extenders look much like the AA4 aftermarket dually adapters, if you pull the wheel off a truck that has them you'll see there is another set of lugnuts that bolts the adapter to the SRW hub and rotor, then the adapter itself has its own set of studs and lugnuts for the wheel to go on them. With the D50 front suspension the easiest way to convert to a dually is to find a pair of these hub extenders and literally bolt them in place of your single wheels, then bolt your dually wheels to them. The other option is to find those dually-specific wheel hubs shown in that picture, with them you'll have to take the locking hubs apart and swap the dually wheel hub onto your D50 spindles, you may also have to transfer rotors between your old SRW wheel hubs and your new dually-specific wheel hubs as they both have the rotor attach to their back side (held in place by the wheel studs in SRW application and by a set of bolts in the dually-specific setup).soooo, these are not the removable dually adapters? cause that is exactly what he has. so what you are saying LCAM-01XA is to just use the d50 stuff? ya'll got me cornfused
Now, did that make more sense, or the muck just got deeper?
