While I wait for my start up video to upload, here are a few more pictures
New radiator and other parts including fans, fan harness, exhaust adapter, gauges, a few things of shrink tubing, and some wire loom
With the electric fans, I really did not like the idea of using the little zip ties included to put it right through the core... plus upon doing a little reading I discovered that some people have not had good luck and actually ruined radiators using them. So I took a few pieces of angle iron, cut and drilled until I had something that would work, and this setup is in no way being supported by the radiator. It uses the 4 holes in the core support that used to be for the original 79 radiator.
The only disadvantage to this setup is that the fans are not all that tight up against the radiator, and I have to make some sort of shroud, or at least some flaps on the top and bottom to keep the air going through the radiator.
