Old_Ironsides
It alters the coolant flow. You know how on the passenger side you have hot coolant exiting the head, running thru the heater core, and returning to the water pump? Well this is pretty much the same setup, minus the heater core. And the T-ee is there because this is the port the overheat temperature switch is installed in from the factory, the switch now resides in said T-ee. Overall idk if such setup is actually helpful or not to an IDI engine. In theory it allows more coolant to bypass the thermostat and return to the water pump for recirculation. Maybe this was done so the engine retains more heat during cold winter driving, the logic being that factory radiators tend to overcool (hence the need for grille covers) in low temperatures and thus if more coolant is recirculated in the engine itself and less is redirected thru the radiator then the thermostat will have an easier job maintaining proper operating temperatures?
Ironsides, I got a possibly silly question for you - did you ever consider using factory big-block engine mounts for your model year? The reason for asking is because IIRC the frame brackets in the factory IDI trucks are stamped "7.5/7.3" meaning they are used for both IDIs and 460s. Following that logic wouldn't it be possible to use '70s frame brackets and drop the IDI mounts on top of them? Or are the '70s and the '80-up 460 motor mounts way different, and thus frame brackets made to work with one don't come even close to fitting the other? Just wondering...
Regarding the brake booster, do yourself a favor and lose the vacuum booster and go hydro now while you have easy access to the firewall. Halfton '70s trucks have quite pathetic brakes IMHO when rolling on anything 33" or larger, even upgrading to the dual diaphragm F350 booster for the respective year is not that big of an improvement. Heck, factory IDIs run much larger brakes, and people still find them lacking in the braking department. So kill several birds with one shot and do the hydroboost from the get-go, you will solve your interference issue with the valve cover (hydroboost can be installed upside-down which moves its reserve canister towards the fender, hot-rod folks do it all the time) and you will make up for the smaller wheel brakes with the increased line pressure. Plus you won't need to run vacuum pump, unless your truck has factory A/C or cruise.
I never really did research going that route with the motor mounts but that does sound like it could have certainly worked if the mounts cross over like that on the newer trucks. The main reason I approached doing the mounts the way I did was because I am working from the tcase mount forward as far as the placement of the drive train, so i can avoid the added cost of having drive shafts lengthened/shortened. Since i am doing this, any factory motor mounts probably would not have been in the right location to bolt right up. If one were to start by placing the engine and then adjusting for the new location of the trans/ transfer case, then it sounds like factory 460 mounts would probably do the trick.
As for the brakes, I would like to end up doing a hydroboost setup, but I have no experience with them so I certainly need to become more educated before knowing what will work for this project. Any suggestions as to what to look for for a hydroboost/master setup that would be appropriate for a setup like this?
