Old_Ironsides
Mag chloride. Liquid rust is what we call it.
Nice job on your build.
ahh... yea that's an accurate name for it...
thanks
Yes, the c's are degrees for caster, and the ones I put in it are the 4 degree ones, which should work out alright when it is all said and done.
As for the hydroboost I have a lead on, it is actually from a c10, not a c30, but I don't know if the mounting between the two is different or not. I'm sure they are different boosters though. If you know that they mount similarly then some rough measurements wouldn't hurt if you have the time to take some.
Ugh, totally forgot about this, sorry! I did measure it just now tho - there are three pairs of holes, half the time the upper pair ain't used even by GM, just the middle and lower pairs. All the holes are 3-3/8" apart horizontally, the vertical distance between the upper and middle pair of holes is 4" and the distance between the middle and lower pair is 2-1/4", all this is center to center. From the mounting plate's face to the center of the eye in the pushrod for the pedal pin to slip into the distance is 7-1/2". All older C/K hydroboosts mount the same and thus interchange, however the bigger the truck the more powerful the booster and thus ideally you want one off a 454-powered C30, but in reality even a halfton one should make your truck attempt a front wheelie
A suggestion on the transfer case crossmember if you don't mind, actually two - weld some small gusset plates to the front and rear walls of the C-channel where the horizontal beam meets the vertical ones, and maybe weld a plate to the t-case mount so it spreads the load across more than just two 3/8" PTO bolts. Other than that it looks pretty overkill, and overkill is good.
Ah yes, I had a blonde moment and forgot about the factory side mount of the case - you should be good then, what you got will work fine. Are you planning on twin-sticking the 205, or does it shift decent enough to leave it factory?
Good progress, it's coming along nicely. Are those the drive shafts from the 79 or the donor rig? Just curious which you ended up using, I don't recall seeing it mentioned anywhere in here.
Thank you. And I haven't talked much about drive shafts, but those are the originals from the 79. The joints I am sure are a little under sized for the job (being 1310's I believe) so that's just another thing I have to keep an eye on. Last thing I want to do is bust a joint and ruin a drive shaft, but I think if I don't get too wild with it and leave it N/A they should hold up alright. Service life may be a little shorter than normal with the joints, but I can live with that.
Well you don't necessarily have to swap or mod shift rails when you twin-stick it, you can keep the factory rails in their factory form - you just have to make sure you rear axle is in the range you want before shifting the front axle in the same range. The rails swap/mod is what allows you to turn just the front axle while rear is in neutral, if you don't want/need that power flow option you just swap the shifters - a good solution to shift linkage that's so loose you can't tell if she's in 2H or 4H, which is sorta what I'm working with
And yeah your U-joints are likely 1310s, one of these days I gotta try and see if a NP208 yoke will fit the NP205 - if it does that's a cheap 1330 upgrade, can even be had in CV (double-cardan) style off a Bronco NP208. I'll let you know what I find out soon.
Yeah, that's what it looked like to me. I had the driveshafts from my donor rig shortened but I forget exactly what I did for joints. I believe that I used whatever was on them already except just replaced them. They fit in the 9" and d44 yokes just fine, so it shouldn't be a big deal for you to swap your joints out. They might even be 1310's, it's just been awhile since I did the shafts. In any case, you're right and you'll be fine as long as you aren't being too wild. I don't beat on my truck, but I do get on it sometimes and the drivelines and everything are holding up just fine.
