Here's what I have done the past few days.
Got the transmission mounted up in its new location, and surprisingly I have not had much for clearance issues yet. One thing I did have to do with the new mount though is to make up spacers to go between the mount and the transmission, since the old mount was one inch taller. I used a piece of 1/2 plate that i had hanging around to make the spacers out of, which luckily enough already had holes drilled that were pretty close to where they needed to be and only required a little massaging with the die grinder to make them work
all bolted up under the truck
Next I hoisted up the IDI and did the first trial fit. It went in, but just barley..
Just from putting a tape measure on it quick, it doesn't look like the mechanical fan is going to be staying when everything is said and done, since the IDI is sitting 3-4 inches further forward than the 351 was.
After this quick fit so I could start visualizing what to make for motor mount towers, I pulled the engine back out and called it a night. Today, I dragged some old plate steel out of the snow and started cutting up pieces for the frame side of the towers.
Then I just finish-welded both pieces and they are ready to bolt on to the frame
And this is as far as I got today. I am going to weld off of these plates so I dont have to weld directly to the frame. These towers certainly aren't going to look factory, but they should be plenty fucntional. I hope to get them finished up in the next few days. The hardest part is going to be figuring out just where the engine needs to be; mainly how high up off the mounts it needs to sit. My thought is to get it set down as low as possible, but I also want to leave ample clearance for the front axle, especially since there is already going to be clearance issues with the oil filter.
